12-12-2016 09:11 AM - edited 03-17-2019 08:55 AM
We have a somewhat usual request from management. Up until now everyone has been required to record a uniform greeting as their standard VM greeting. Now, they want everyone to start using the system default greeting instead of the standard greeting they have recorded. This goes across Cisco Unity version 11.5.1 and CUE version 8.6.7 as we have both (CUE in remote offices). I tried going through the VM menus and while I can rerecord the standard greeting, there doesn't seem to be a way to tell the system to use the system default greeting. Is there any way users can go in and tell the system to use the system default greeting for the standard greeting instead of the one they recorded? Thanks.
12-12-2016 11:46 AM
You as an administrator can do this individually or in bulk by changing user --> Greeting --> Standard Greeting --> check "System Default Greeting".
Or users can do it from ciscopca page.
12-12-2016 11:53 AM
Hi there,
+5 to my friend Chris for his great thoughts on this.
I would use this excellent tool from the great suite of Unity Tools (use the ** reset" feature **) to delete the greetings/recorded name depending on what management exactly wants to hear (see below) You would want to test this on some individual mailboxes before going all in!
ie:"Sorry extension is not available" or "Sorry Recorded name is not available"
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox, resetting greetings, deleting voice names, resetting passwords, removing private lists and a number of other options you may choose. For installations where the user base “changes over” frequently such as schools this may be a nicer option. This option is also allowed for CoRes installations since it does not involve the removal of user objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
So you'd need to tweak as detailed nicely by Greeshma from Cisco as shown below;
"This is the normal behavior which is the feature of TTS (text to speech).
I'm not sure about CUE, but I'' try and do some research.
Cheers!
Rob
