Allowing callers to dial extension on call handlers
2mykhan
Beginner
Beginner
Hi All,
I have setup the system call handler to allow users to dial extensions however when i dial the extension number i get the message "you cannot be transfer to this number, check the number and try again"
I have selected the option in Greeting "Allow Transfers to Numbers Not Associated with Users or Call Handlers"
also the extension numbers are not  in restriction table.
5 Replies 5
Suresh Hudda
It can be issue due to partition/css, so check partition & CSS as well at cti port/sip trunk, phone' ext as well.
Suresh
Hi Suresh,
If is set the call to forward to other extension in after greeting  it works so i think the partion and CSS is not the concern here.
anything else can be checked?
Is it happening for all calls ? If then it can be dtmf issue as well. Can you explain call flow (e.g. pstn -> h323/mgcp/sip -> cucm -> sip/sccp -> cuc)
Suresh
I thought so it could be a dtmf issue but  as i said when the calls goes to other extensions we are able to enter the extension# and PIN(access voicemail box) and the system accepts it.
Call flow is PSTN->h323->cucm->sccp>cuc
Is this "when the calls goes to other extensions we are able to enter the extension# and PIN(access voicemail box) and the system accepts it" working when you call from PSTN to voice mail ? if its working then it not seems issue with dtmf.
Suresh
