Alternate greeting schedule CUUC 8.x
George Banuelos
Beginner
Beginner
How can CUUC 8.x be used to automatically play standard voice mail greetings Monday-Friday and then automatically play alternate greetings on Weekends?
Thank you!
George
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
You need to configure standard greeting for working hours, and closed greeting for afterhours/weekends.
java
if this helps, please rate
Jaime Valencia
java
Thank you Jaime... the thing is that in the voice mail account active schedule, it only allows for 1 option... I'm assuming that if I select working hours for the active schedule, the closed greeting will automatically kick on - is this correct?  if not, could you please provide a little more guidance on how to set this u?
Thank you again!
never mind Jaime... thank you for your input, I read that the Closed Greeting will override based on the active schedule parameters, thus confirming the assumption was correct.
Recognize Your Peers
