Alternative for cisco sip proxy server
We are looking for SIP proxy servers. When I checked cisco, cisco proxy servers are no longer available http://www.cisco.com/c/en/us/products/unified-communications/sip-proxy-server/index.html. What is the alternative product for cisco proxy servers?
In  our lab, we have a Voip Gateway (series:  C2900, IOS: 15.3(3)M), 2 CUCMs  (version  9.1  and 10.5)  and around 20+ phones.
Is it possible to use our existing Voip Gateway as a sip proxy server?
Pandi
2 Accepted Solutions
Vivek Batra
AFAIK, SIP proxy is RFC term and not used in enterprises. B2BUA is used indeed. CUCM and CME both are back-to-back-user-agent (B2BUA).
Call Manager Express runs inside the IOS and you can use it as a SIP server.
Do you expect any thing specific from SIP proxy?
- Vivek
Hi Pandi,
From top level if you see, both CUCM and Gateway are acting as SIP proxy because both are processing SIP messages independently however from RFC perspective, these are not SIP proxies indeed B2BUA. SIP proxies come in two flavors viz stateful and stateless. Although stateful proxy maintains the transaction state, but B2BUA is more than that which treats each call leg of a call independently.
Anyway CUCM can do all jobs mentioned by you.
- Vivek
5 Replies 5
Vivek Batra
- Vivek
Thanks Vivek,
We are looking SIP proxy for routing, registration, accounting and authorization.
Our lab setup looks like the below one.
IP Phone => CUCM => Gateway => SP Provider Network
In this case, our CUCM will act as sip proxy right? Or our gateway?
Pandi
Hi Pandi,
- Vivek
Thank you so much Vivek.
You're most welcome!
- Vivek
