1337
a.shaik
Beginner
Annunciator for SIP Phones
Hi all,
I configured all phones with SIP firmwares (7942 and 7965) with CUCM 7.1.3 release. It seems that annunicator is not working. I have tested with SCCP phone and it's working fine.
It seems that annunciator deal only with sccp. Is there any way to configure Annunciator in SIP.
Shaik ASSANA
5 REPLIES 5
Jaime Valencia
Hall of Fame Cisco Employee
Annunciator
An annunciator is a software function of the Cisco IP Voice Media  Streaming Application that provides the ability to stream spoken  messages or various call progress tones from the system to a user. It is  capable of   sending multiple one-way RTP streams to devices such as  Cisco IP phones or gateways, and it uses SCCP messages to establish the  RTP stream. The device must be capable of SCCP to utilize this feature.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046552
There is no way to modify the behavior.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
hi ,
i have sip 6921 phones working with annunciator .
can u tell me how this is working
cucm 8.5
sip 9.1.1.1  firmware for phones
paolo bevilacqua
Hall of Fame Master
Why SIP, less features, more bugs.
As you just found.
Karthik Sivaram
Enthusiast
Annunciator support for sip phones is available from  callmanger version 8.0 :
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps10662/data_sheet_c78-584298.html
Hope that helps!
Karthik Sivaram
thanks man
Create
Recognize Your Peers
Content for Community-Ad
