02-06-2019 07:53 AM - edited 03-17-2019 02:04 PM
For a customer we have 5 accounts (CSF)
These accounts are not allowed to find any other accounts in phonebooks, and are only allowed to call each other (5 accounts)
This needs to be done in the cucm.
Anybody idea whats the best way i can make a workaround for this.
Should i place all the accounts in specific css and partitions?
02-06-2019 08:23 AM
Yes, CSS and partitions for calls
If you're using UDS, there's no way to prevent them from finding someone else, if you're using LDAP, configure them in a separate OU and configure their service profile so they can only look into their own OU with just them.
02-06-2019 08:58 AM
Hell Jaime,
Can you suggest any reference for quick comparison of what you win and lose between Using UDS and LDAP ?
George
02-06-2019 09:19 AM
UDS is a flat directory and you have little to no control over the field mapping, etc.
LDAP allows you to configure search bases and filters, point to specific LDAP/GC, use SSL, adjust the field mapping, configure LDAP groups, etc.
02-06-2019 09:47 AM
Thanks a lot!!
I am using LDAP and I was wondering what I may be missing.
George
02-06-2019 06:10 PM - edited 02-06-2019 06:11 PM
Adding to Jaime’s response: Ambiguous Name Resolution (ANR, a MS AD feature) doesn’t work with UDS. You also lose two possibly useful attributes: jpegPhoto (must use URL substitution to a HTTP server) and otherTelephone for secondary number lookups.
UDS also has a load on CUCM that you cannot assign to dedicated nodes as you do with all other services. This can become a design issue at scale.
Despite all of that, it’s the only option that works for MRA-connected endpoints or CE endpoints, unless you redirect them to TMS.
My design default is UDS but there are customer environments where I need to use CDI/LDAP instead.
