Answered call dialog box obscures labels on buttons on right side of screen on 8851
NGrubb
We have the 5 buttons on the right side of the screen of our receptionist's 8851 programmed for speed dial/transfer for certain important extensions.  However, when she answers a call, the answered call dialog obscures the on-screen labels for those buttons, making them useless.
Is there a way to shrink or eliminate the answered call dialog box?
Thanks in advance for any solution.
5 Replies 5
Jaime Valencia
No, you'd need to reach out to your SE/AM and submit a PER.
java
if this helps, please rate
Any way you could answer again without the acronyms?  I have not the slightest idea what your reply meant...
Systems Engineer
Account Team
Product Enhancement Request
java
Bingo!
Thank you.
Found a simple fix:  When on the call, press the physical "back" button on the 8851 and the dialog will disappear from the screen and allow you to see the screen labels for the buttons on the right.
