Any Limitations on OS Admin account creation?
Dear Team,
I would like to create 15 users accounts with the privileage level of 4 for the CUCM's OS Administration access. I would like to know is there any limitations that only a specific no. of users should be created on the CUCM Platform Access?
I am running with the CUCM and Unity Connections of 8.5.1
Mohsin..
Jaime Valencia
If you mean in the amount of users, no, there is currently nothing on limits for that.
They're just an entry in the Linux system with the level of privilege you want them to have.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
