AnyConnect and RNDIS device
RobertWiesner
I'm wondering if someone knows how to work around an issue with using Cisco AnyConnect 4.5 connected to the company network and a RNDIS enabled USB device (end point, no router capability). It seems that if I connect to the company network, the RNDIS device does not enumerated or as an alternative, if I'm not connected to the company network (disable Wi-Fi & not wired connection) I can connect fully to the RNDIS gadget device but enabling the external IP connection (enabling Wi-Fi or reconnecting the wire Ethernet), it will not connect to the company. It seems AnyConnect is limited to exactly one external Ethernet connection.
I appreciate suggestions how to solve this.
Robert
Chris Deren
Robert,
You asked this question on Cisco IP telephony forum, do you have related question to this technology?
If not you might be better served by other Cisco forums i.e. Wireless, Security, etc.
