Applying NTP reference to IP Phones
mahmoodmkl
Rising star
Rising star
Please clarify whether applying the NTP reference to date/time group in turn this date/time group is assigned to device pool is it going to require the phones to be restarted..
5 Replies 5
Aman Soi
Advisor
Advisor
Hi Mahmood,
the phones would restart .
Adding a Date/Time Group
After adding a new date/time group to the database, you can assign it to a device pool to configure the date and time information for that device pool.
You must reset devices to apply any changes that you make.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/a02sycfg.html#wp1074727
the same would happen for NTP as well.
further, other nodes also need to be restarted in cluster for changes to happen.
https://supportforums.cisco.com/thread/2184534
regds,
aman
Thanks for the reply.
Please confrim whether just adding the NTP reference without assigning to any date/time group will cause any reset of IP Phones.
Hi Mahmood,
I do not think so but let me check.
regds,
aman
Hi.
As Aman stated(+5 P Aman) you don't need to reset anything if you just add a new ntp reference without assign it.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
thanks for confirming.[+5]
regds,
aman
Recognize Your Peers
