AS5400XM replacing AS5300 - can't configure modem lines
ricklefevers
Have AS5400XM replacing AS5300, will be used for asynch ports (modem).
Basically user will telnet/ssh into AS5400XM and dial out to remote modems using AS5400XM modem functionality (asynch lines).
Box has Dial feature card (AS54-DFC-2CT1) and HD PV feature card (AS5X-FC). We need modem lines (TTY) same as AS5300. No TTY lines show up.
TAC advised to order AS54-DFC-60NP but found it is EOL.
Is there a new way we are not familiar with to enable modem lines? Or do we need this card which is no longer made?
Not very familiar with the product here.
Any ideas apprecited, thanks rick.
ricklefevers
Never mind, after being told to order 2 different modules by Cisco which are both EOL we finally found our own answer - replace the AS5400 with and ISR and use PVDM2-24DM which comes in 12, 24 & 36 channel varieties - lovely!
