ASA 8.4(1) and CUCM 8.5(1) phone proxy slow dialing ?
Erick Bergquist
Frequent Contributor
Recently upgraded call manager from version 6.x to 8.5.1 and phone proxy worked fine before but on new version, the phones work but dialing is delayed and entering voice mail passwords is delayed. So seems signally related items are delayed, the rtp audio stream is fine however once call is established.
Here is some info and snippets from the config, anyone seen this?
ASA version 8.4(1)
CUCM version  8.5.1.10000-26
7941 phones - firmware SCCP41.9-1-1SR1S
172.16.1.20 - cucm pub
172.16.1.21 - cucm sub
tftp running on both servers
12.x.x.108 - PUBLIC IP NAT for CUCM PUB
12.x.x.12 -- ASA outside IP
object network obj-172.16.1.20
nat (INSIDE,OUTSIDE) static 12.x.x.108
nat (OUTSIDE,INSIDE) source dynamic any interface destination static obj-12.x.x.108 obj-172.16.1.21
media-termination MTA
address 12.x.x.109 interface OUTSIDE
address 172.16.1.15 interface INSIDE
phone-proxy asdm_phone-proxy
tftp-server address 172.16.1.21 interface INSIDE
tls-proxy TLSProxy
ctl-file myctl
no disable service-settings
proxy-server address 172.16.1.21 interface INSIDE
luisroja
Beginner
Beginner
Greetings,
Currently, ASA phone Proxy feature is not supported with CUCM 8.5. I guess that on this scenario your option would be to use the Phone VPN feature on the ASA.
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/unified_comm_phoneproxy.html#wp1241209
Supported Cisco UCM and IP Phones for the Phone Proxy
Cisco Unified Communications Manager
The following release of the Cisco Unified Communications Manager are supported with the phone proxy:
•Cisco Unified CallManager Version 4.x
•Cisco Unified CallManager Version 5.0
•Cisco Unified CallManager Version 5.1
•Cisco Unified Communications Manager 6.1
•Cisco Unified Communications Manager 7.0
Here is the Support Forums Documentation for the IP Phone SSL VPN using AnyConnect.
https://supportforums.cisco.com/docs/DOC-9124
Hope this information helps.
Thanks.
--Armando Rojas
