Walkthrough Wednesdays
894
Piotr Mlodawski
Beginner
ASCOM IP-DECT Jabber Deskphone Control in CUCM 10.5.2
Hello Everyone,
Is Jabber Desk Phone Control of ASCOM IP-DECT telephones supported in CUCM? (IP-DECT Gateway)
ASCOM DECT  telephones are registered in CUCM as Ascom IP-DECT Device (COP file was uploaded) not as 3rd party SIP.
Standard configuration of Desk Phone Control fails to connect to the desk phone.
Piotr
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Desk phone control relies on CTI, if it doesn't support CTI, then it won't work.
java
if this helps, please rate
4 REPLIES 4
Jaime Valencia
Does that device supports CTI?
java
Thanks for the reply Jamie,
On the ASCOM IP-Dect device I do not see an option "Allow Control of Device from CTI"
"CTI Control" option is only available on the Line.
Piotr
Jaime Valencia
java
Hello Jamie,
This hast to be case.
Content for Community-Ad
Spotlight Awards 2021
