7355
Highlighted
Community Manager
Ask the Expert: Designing, Configuring & Monitoring of Cisco Unity Connection
Designing, Configuring & Monitoring of Cisco Unity Connection with Aashish Jolly - Read the bioWith Aashish Jolly
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about Designing, Configuring & Monitoring of Cisco Unity Connection with Aashish Jolly.
This is an opportunity to learn more about & ask questions about Designing, Configuring & Monitoring of Cisco Unity Connection.
Aashish Jolly is a network consulting engineer who is currently serving as the Unified Communications (UC) consultant for the ExxonMobil Global account. Earlier at Cisco, he was part of the Cisco Technical Assistance Center, where he helped customers Cisco partners with installation, configuring, and troubleshooting UC products such as Cisco UC Manager and Manager Express, Cisco Unity solutions, Cisco Unified Border Element, voice gateways and gatekeepers, and more. He has been associated with Cisco UC for more than seven years. He holds a bachelor of technology degree as well as CCIE(Voice) # 18500, CCNP Voice, CCNA, VCP 5 and RHCE certifications.
Aashish might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Security sub-community forum shortly after the event. This event lasts through April 2, 2013. Visit this forum often to view responses to your questions and the questions of other community members.
1 ACCEPTED SOLUTION
Highlighted
Hi Arun,
   For unified messaging, I would consider the following
1. Exchange on-premise (2003, 2007 or 2010) or cloud (Office 365)
2. What UM features you're looking for i.e. Single Inbox, SpeechView, TTS, Access to Exchange Calendar etc. For more details, I suggest the following -
Introduction to Unified Messaging in Cisco Unity Connection 9x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/unified_messaging/guide/9xcucumg010.html
3. UM accounts that are created in Exchange with role of ApplicationImpersonation. For more details on Unity Connection Single Inbox and Exchange 2010 performance characteristics, I recommend the following document
Cisco Unity Connection Single Inbox with Microsoft Exchange 2010
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/solution_overview_c22-713352.html
4. UM Service to be created on Unity Connection. This can be used for granting UM feature access to users.
For example, you might configure one unified messaging service that enables text to speech (TTS), another that enables access to Exchange calendars and contacts, and a third that enables single inbox. With this design, if you want a user to have access to all three features, you would create three unified messaging accounts for the user, one for each of the three unified messaging services.
5. Number of users with UM feature is the same as a voice messaging deployment, however the following consideration applies "Allowing Connection or Exchange mailboxes larger than 2 GB can affect Connection and Exchange performance."
6. Populating SMTP Proxy address field in unity connection for each user with UM access. This is the user's exchange email address or use Viewmail for Outlook (VMO) as it addresses messages to Unity Connection only.
7. Firewall b/w Unity Connection & MS Exchange. For more on ports used by Unity Connection, refer to
IP Communications Required by Cisco Unity Connection 9.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/security/guide/9xcucsec010.html
8. Bandwidth Requirements. For that I recommend going through the following document
Requirements for Using Unified Messaging Features
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/requirements/9xcucsysreqs.html#wp515351
9. Round Trip Latency should be less than 250 ms. Sync threads required for mailbox sync or else users may experience delays. The default is 4 and the max is 64 (can be changed by a CLI command). For more details on latency and calculating connections needed, refer to Latency section in the design guide located here -
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/design/guide/9xcucdg032.html#wp1132131
10. Whether or not secure voicemails are required by user with UM access.
11. Mailbox quotas & messag aging in connection. As mentioned earlier having mailbox size of 2GB or more can affect Exchange & Connection performance. So having mailbox quotas & message aging policy can help in improved performance. Preferrably have the same quota at both ends.
From a deployment perspective, you need to consider the following
1. UM accounts & services to be used for UM features
2. Populating SMTP Proxy address. One way of doing this is to enable LDAP sync and creating a user template with Generate SMTP Proxy Address with corporate email address checkbox checked. If you're adding users via BAT, the field is CreateSmtpProxyFromCorp. In case you're updating existing users the field is SmtpProxyAddresses. For details, I recommend the following document -
Using the Cisco Unity Connection 9.x Bulk Administration Tool
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/user_mac/guide/9xcucmacappa.html
3. For more details on configuring UM for Unity Connection, I recommend the following guide
Unified Messaging Guide for Cisco Unity Connection Release 9.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/unified_messaging/guide/9xcucumgx.html
References
Single Inbox in Cisco Unity Connection 9.x - Design Guide for Cisco Unity Connection Release 9.x
HTH,
Aashish
31 REPLIES 31
Highlighted
Advisor
Hi Aashish,
What exactly is the command to monitor UCxN working in HA mode , the way we do in Cisco Call Manager [utils d breplication runtimestate]?
regds,
aman
Highlighted
Hi Aman,
The cli command show cuc cluster status is one possible way. The  second group of information displayed by the command pertains to database replication. If database replication is running, the State field for both the pub and sub server should be Active and the Status field should show Connected for the other server. Here's an example of the command output for both a Pub and Sub where database replication is working properly:
Command run on the Pub:
admin:show cuc cluster status
Server Name   Member ID  Server State  Internal State  Reason
sea-vm-ks-16  0          Primary       Pri Active      Normal
sea-vm-ks-17  1          Secondary     Sec Active      Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_pub      100 Active   Local           0
g_ciscounity_sub1     101 Active   Connected       0 Nov 22 10:55:57
Command run on the Sub:
g_ciscounity_pub      100 Active   Connected       0 Nov 22 10:55:57
g_ciscounity_sub1     101 Active   Local           0
Here's an example of running the command on the Pub where database replication with the Sub is disconnected:
g_ciscounity_sub1     101 Active   Disconnect      0 Nov 22 17:15:33
Here's an example of running the command on the Pub where database replication has been torn down and is not running:
Database replication is not active
For more details on Unity Connection Clustering, I recommend the following post -
https://supportforums.cisco.com/docs/DOC-5963
HTH,
Aashish
Highlighted
Thanks alot Aashish.Excellent explaination along with supporting URL.
Highlighted
Hi Aashish,
My requirement is to receive  the incoming fax from outside to my Email. Is there any way to achieve this without using third party server like RightFAX and configure FAX option if available in UCxN ?
Please advice.
regds,
aman
Highlighted
Hi Aman,
    Currently fax integration in Cisco Unity Connection requires a Fax Server. The following 3rd party fax servers are supported
OpenText Fax Server, RightFax Edition, versions 9.x and later. For more information, see the www.opentext.com
Sagemcom Xmedius Fax SP version 6.5.5. For more information, see the www.sagemcom.com.
Cisco Fax Server, version 9.x
Note Cisco will no longer be selling Cisco Fax Server version 9.x after May 2011; however, support for Cisco Fax Server will continue until May 2014. For detailed information on end-of-sale and end-of life dates for the Cisco Fax Server, see the information at http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/end_of_life_notice_c51-630608.html.
For more details, I recommend the following interesting reads
Cisco Fax Server Integration in Cisco Unity Connection 9.x - Design Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/design/guide/9xcucdg080.html
Creating a Cisco Fax Server Integration in Cisco Unity Connection 9.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsag246.html
HTH,
Aashish
Highlighted
Beginner
Hi Aashish,
How are the resources planned on the Cisco Unity for an enterprise having 400 users which would later scale upto 1000 users with basic Voice mail features.
Dilip kumar
Highlighted
Hi Dilip,
   I assume you're referring to Cisco Unity Connection here as Cisco Unity went end of sale in Jan 2012. Considering Unity Connection 9.1.1, a 1000 user system would need the following
vCPU = 1 (2.13 GHz reserved)
vDisk = 1 x 160 (file system aligned at 64KB blocks)
vRAM = 4 GB
You also get the following with this template
Approximate message storage, G-711 codec, minutes = 72,944
Voice Ports per server = 24
Users = 1000
For more details, I recommend the following interesting documents
Specifications for Virtual Platform Overlays for Currently Shipping Connection 9.x Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html#wp703559
OVA Template Details for Unity Connection Release 9.1.1
http://docwiki.cisco.com/wiki/OVA_Template_Details_for_Unity_Connection_Release_9.1.1
Download Cisco Unity Connection 9.1.1 OVA
http://software.cisco.com/download/release.html?mdfid=283062758&flowid=31846&softwareid=282074348&release=OVA-9.1&relind=AVAILABLE&rellifecycle=&reltype=latest
HTH,
Aashish
Highlighted
Aashish,
Thanks for the detailed response on the scalability design.
Dilip
Highlighted
Hi Ashish,
This discussion post is really interesting and helpful.. I have a basi question here.. Since i came into Designing work newly.
As per the Cisco Recommendation 24 ports for Standalone Cluster and 48 Ports for Active/Active Cluster config. May I know how these 24 ports are mapping to 1000 users?
Bala
Highlighted
Hi Bala,
   The typical port to user ratio is 1:40, with that in mind, we will require 24 ports as the license is available in increment of 2 and hence 25 ports is not possible.
Aashish
Highlighted
Hi Aashish,
Yes, It was there in my mind befiore i ask the question, But if we apply that ratio for 10,000 or 20,000 users, Output is coming in different figures from Cisco Recommendation.
Example:
For 10,000 users
As per 1:40 ratio calculation = 0.025 * 10000 = 250 Ports
As per Cisco Recommendation = 150 Ports
For 20,000 users
As per 1:40 ratio calculation = 0.025 * 20000 = 500
As per Cisco Recommendation = 250 Ports
It would be great if you clear my confusion here, Thanks again..
Bala
Highlighted
Hi Bala,
   That is a good question and I never paid attention to it. Typically we just deploy as is, however I'm researching further to get clarification on this point i.e. to find out the factors contributing to the port calculation and I'll keep you posted on it.
Aashish
Highlighted
Beginner
Hi Aashish, I have a recurring issue with Unity Connection remote port status monitor application.  When I attempt to use this I have already enabled "port status monitor output" and added my IP address to the list of allowed IP hosts in the Conversation section of Advanced settings.
I am using rPSM 2.0.0.16 and  UnityConnection 8.6.1 or 8.6.2.  I've noticed that I will get the "Connection  refused by remote server - make sure the IP address of the client  machine you're running remote port status monitor on is included in the  list on the Connection server that allows for remote connections.  See  help for more details." error message.
If  I am patient enough, and keep trying it will eventually let me in after 5 or 10 minutes.  Is  there a service I can restart to speed this conversation up or do I just  need to wait for the timeout value before the allowed list is  refreshed?
thanks,
Kasey
Highlighted
     Hi Kasey,
   The issue you've mentioned is quite strange. I would try the following
1. Update to the latest version available here -
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
2. Double check unity connection configuration for RPSM i.e.
    - 'Enable Remote Port Status Monitor Output' Checked
    - IP Addressess Allowed to Connect For Port Status Monitor Output (comma-separated) populated with client IP      Address.
3. If the issue persists, restart Connection Database Proxy & Connection Realtime Monitoring API's
4. If the issue is still persistant, we'll have to grab packet captures to see what is happening on the wire.
Aashish
