Community Helping Community
7298
Hi Terry, Just explain little
Hi Terry,
Just explain little more, where the users connect depends on the DNS reply. Hence, we should configure the DNS in site A to resolve to DC1 and DNS in site B to resolve DC2.
Hari
Advocate
Thanks Jyothi and Hari. +5.
Thanks Jyothi and Hari. +5. There are no ratings on any of the posts here, I am going to rate all posts and will request the community to rate the responses as well, to appreciate the help you are receiving and saying thank you to these guys, for helping us.
Amit, jyothi and Hari +5 on your way for all your posts :)
Hari I though the same, but can we configure DNS servers to resolve the names according to the source subnet or how the DNS is actually configured in this case? I know this goes outside of CWMS and more into DNS configuration but still thought will just check with you.
-Terry
Hi Terry, Thanks for the
Hi Terry,
Thanks for the ratings. I am not sure whether a DNS server can provide resolution based on the source subnet. Since we are reffering to different sites, I assume that there will be different DNS server for each site. Each DNS should resolve the IP address of their local site. While assigning the IP address to the client, we should assign the respective DNS server. In this way the clients connect to the local site.
Hari
Hello Terry,Have you
Hello Terry,
Have you investigated on "Subnet Prioritization", you may want to check this, if I understand your query correctly: https://technet.microsoft.com/en-us/library/cc961422.aspx
If not, we can have a quick call to discuss and see, if we can find an appropriate solution.
Amit Singh
Advocate
Hi Amit,I haven't actually.
Hi Amit,
I haven't actually. Thanks for providing the above link (+5) - I will certainly read it and will let you know if I have further questions.
Thanks Again for your response and your offer for the call - much appreciated.
-Terry
Advocate
Thanks Hari! (+5)
Thanks Hari! (+5)
Enthusiast
Hello, Thank you for this
Thank you for this opportunitiy.
I have now new implemenation for Webex server. and my first question:
Is it a must to use vCenter to deploy Webex?
Hello, Thats correct, its a
Thats correct, its a requirement/Pre-requisite to deploy CWMS using vCenter.
http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_0/Planning_Guide/Planning_Guide_chapter_00.html
Additionaly, We recommend vCenter as best practice, if you need to restore your VM's for some reason.
Amit Singh
Enthusiast
Thank you for your reply, +5
Regarding vCenter, as per my knowledge we have vCenter Windows based and vCenter Appliance. can I use any one?
and I did not find vCenter within the software that I got from Cisco. and when I tried to download from VMware I found the following products:
VMware vCenter Application Discovery Manager
VMware vCenter Chargeback
VMware vCenter Converter Standalone
VMware vCenter Operations Manager for Horizon View
VMware vCenter Server Heartbeat
VMware vCenter Site Recovery Manager
Could you please help?
Hi, We can use windows based
We can use windows based vCenter or vCenter appliance. This actually depends upon how many ESXi hosts that you would like to manage with one vCenter. From CWMS perspective, we can use both any one of them.
if you are referring to vCenter client Software, this is not provided by cisco. You can access the vCenter via https [https://<vCenter-IP>] and this will give you an option to download vCenter Client.
Hari
Enthusiast
Hello Hari, Do I need the
Hello Hari,
Do I need the vCenter after the installation? In other words can I remove the vCenter after making CWMS up and running?
Hi, vCenter might not be
vCenter might not be required for the system to function, however this is not tested. Most the of the vSwitch configuration are done via the vCenter, hence I am not sure whether removing the vCenter will break the vSwitch configuration.
Also, we will need the vCenter during maintenance / troubleshooting / upgrade. I would suggest leave the vCenter running as it is easy manage the hosts.
Hari
Enthusiast
Hi, I found another server
I found another server under vSphere, vCenter Server. can we use the appliance one? or I should use the one which is Windows based?
Highlighted
Hi, You can use any of them
You can use any of them as per your requirement.
Hari
VIP Advisor
Thanks guys for this forum
Thanks guys for this forum post.
we currently run CWMS v.2.5 including a WebEx external/DMZ virtual machine.  We need to change the IP address on this webex proxy. Will this have any implications on the licenses? i.e. will the license need to be re-hosted to reflect the new IP address on the webEx proxy?
Cheers
Please remember to rate useful posts, by clicking on the stars below.
Content for Community-Ad
FusionCharts will render here
