01-21-2020 04:31 AM - edited 01-21-2020 04:32 AM
Hi Team,
We have a request to grey out(block out) credentials on a specific application user in CUCM 10.5. Whereas, End user should have access to add/remove Device and CTI information on the same application user.
Gopinath M
Solved! Go to Solution.
01-24-2020 06:59 AM
No version has what you're looking for.
01-21-2020 06:16 AM
That's not possible, permissions are only granular as whether you have access to the whole end user/application user pages or not.
01-24-2020 03:33 AM
Hey Jaime,
Thanks for your response. Is this feature supported in CUCM version 11.0 and above ?
Gopinath M
01-24-2020 06:59 AM
01-28-2020 01:21 PM
Hi Jaime,
Thanks for your prompt response
01-28-2020 01:26 PM
Thanks for the inputs Jaime
Gopinath M
