Assign privileges to specific User in CUCM
GopinathMani
Hi Team,
We have a request to grey out(block out) credentials on a specific application user in CUCM 10.5. Whereas, End user should have access to add/remove Device and CTI information on the same application user.
Gopinath M
No version has what you're looking for.
java
if this helps, please rate
5 Replies 5
Jaime Valencia
That's not possible, permissions are only granular as whether you have access to the whole end user/application user pages or not.
java
Hey Jaime,
Thanks for your response. Is this feature supported in CUCM version 11.0 and above ?
Gopinath M
java
Hi Jaime,
Thanks for your prompt response
Thanks for the inputs Jaime
Gopinath M
