01-29-2015 09:10 AM - edited 03-17-2019 01:46 AM
we currently have 3 digit extensions for our users and we are running low on them. We currently dial 9 to get an outside line, is there a way for me to assign users an extension starting with 9 without having to wait for the timeout or press #?
01-29-2015 09:22 AM
As long as there is overlapping, you'll have to wait for IDT to expire or press # to place the call, using the same digit you use for PSTN calls internally is a very poor choice.
I assume you're already having to use the 9xx range, you'd be better off doing a re-design of your dial plan and expand to 4+ digits as required.
01-31-2015 01:51 PM
If You will change t.302 timer to 3 seconds (minimal value) U will wait only 3 seconds then call will flow
