Hello Cisco Community,
I'm new to Cisco Collaboration and work as Junior in my Department.
I would like to get some assistance for the following:
Our company has purchased 10 DID numbers that I need to setup and configured.
The PSTN provider is presenting 6 digits to our gateway.
now, I have a few questions about this as beginner:
do we have to configure DID numbers in both our gateway and CUCM?
The following pots dial peer is already configured
dial-peer voice 100 pots
translation-profile incoming e1-000-in
destination-pattern 9T
progress_ind setup enable 3
incoming called-number .
direct-inward-dial
port 0/1/0:15
So I was thinking of adding the following voip dial peer:
dial-peer voice 105 voip
preference 1
destination-pattern [4-6]...
session target ipv4: Call Manager IP
incoming called-number 85539.
direct-inward-dial
voice-class codec 10
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
Then in call manager I would create the following translation pattern:
855390 --------- 1000
855391 --------- 1001
855392 --------- 1002
855393 --------- 1003
855394 --------- 1004
855395 --------- 1005
855396 --------- 1006
855397 --------- 1007
855398 --------- 1008
855399 --------- 1009
Translation Pattern:8553XX
Called Party Transformation Mask: 1XXX
does the about sound correct? Will it work with that configuration?
Thanks in advance!
Yes, you configure both the GW and CUCM.
A DID you usually want the SAME number on the device (111 222 3333 outside, phone gets 2223333/2333/12223333/etc as per dial plan), google DID/DOD
If they want to change it as you mention, that's also doable.
You probably want to start by reviewing the dial peer configuration guides, and the dial peer matching documents to understand how that works.
thanks very much for answering my questions! this helps a lot
in a dial peer configuration what's the difference between destination-pattern and
incoming called-number ?
@DamianMartinez wrote:thanks very much for answering my questions! this helps a lot
You need to understand that dial peers are used to match both incoming calls and outgoing. "incoming called-number" is one of the methods the gateway uses to try to match an incoming call. "destination-pattern" is one of the methods the gateway can use to try and decide which dial peer to use for an outbound call. Inbound and outbound from the gateway's point of view. PSTN->Gateway is inbound, Gateway->CUCM is outbound.
Referring to your dial peers 102 and 103 you have "destination-pattern [4-6]..." which a four digit dialled number starting 4, 5 or 6. How does that relate to your number ranges?
thanks! those dial peers where configured before, nothing to do with the new DID numbers.
so in a pots dial peer, what does destination-pattern 9T mean?
@DamianMartinez wrote:thanks! those dial peers where configured before, nothing to do with the new DID numbers.
To specifically match the new DID numbers you want destination pattern of "85539." To properly design these dial peers we'd need to know what other numbers are being handled. For example those DPs 102 and 103 are expecting four digit numbers, are those numbers still live? It would be unusual for an ISDN to present six digits for some numbers but only four for others.
"destination-pattern 9T" matches any number that starts with 9 followed by any number of digits. In the case of a POTS dial peer this also has the effect of dropping the 9 from the number before sending to the PSTN. So for example "91234" would match that dial peer but only "1234" would actually be dialled.
The "T" derives from "Timeout" meaning if the digits were being received individually it would be waiting for a timeout to decide the number was complete.
@DamianMartinez wrote:Translation Pattern:8553XX
Called party transform mask of 1XXX will retain the last three digits of the matched number. For example 855395 will translate to 1395. To get the results that you show in your table the mask needs to be 100X. For the translation pattern itself I would prefer longest match possible, 85539X.
Regarding dial peers, the gateway have have any existing numbers routing to CUCM, if so the how are the dial peers configured?
In your proposed DP 10-5 you have " incoming called-number 85539". I don't think that's going to do what you want. If you want DP 105 to match calls from CUCM to the gateway then you want "incoming called-number 9T".
thanks for the clarification, I have updated call manager procedure for translation patterns
Translation Pattern:85539X
Called Party Transformation Mask: 100X
About dial peers, we have the following configured:
dial-peer voice 103 voip
preference 1
session target ipv4:Call manager IP
voice-class h323 1
no vad
dial-peer voice 102 voip
session target ipv4: Second Call manager IP
voice-class h323 1
no vad
about your comment below:
if you want DP 105 to match calls from CUCM to the gateway then you want "incoming called-number 9T , can we also use incoming called-number . ?
Thanks!
