07-12-2017 11:50 PM - edited 03-17-2019 10:46 AM
We are having issues setting up an H323 Gateway on our 3945 Router. To route calls from my PSTN to CUCM.
I have found multiple documents, relating to this issue, we have also updated it to be exactly the same.
The ip address on CUCM and my gateway loop back match and port 1720 is open.
I want to set it up to only accept calls not to dial out on hence only one dial peer.
Thanx
Running config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no h225 timeout keepalive
voice class h323 1
h225 timeout tcp establish 3
interface Loopback0
ip address 10.20.44.7 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.20.44.7
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
dial-peer voice 100 voip
preference 1
destination-pattern .T
session target ipv4:10.25.1.50
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
debug ip tcp transaction
Jul 12 19:35:56.748: TCB10324200 created
Jul 12 19:35:56.748: TCB10324200 setting property TCP_NO_DELAY (0) 2EE55AC
Jul 12 19:35:56.748: TCB10324200 setting property TCP_TOS (11) 2EE55D0
Jul 12 19:35:56.748: TCB10324200 setting property TCP_NONBLOCKING_WRITE (10) 2EE55E8
Jul 12 19:35:56.748: TCB10324200 setting property TCP_NONBLOCKING_READ (14) 2EE55E8
Jul 12 19:35:56.748: TCB10324200 setting property TCP_KEEPALIVE (17) 2EE55E8
Jul 12 19:35:56.748: TCP: Setting Keepalive interval and retries to 60 and 4
Jul 12 19:35:56.748: TCB10324200 setting property TCP_VRFTABLEID (20) 1391BC68
Jul 12 19:35:56.748: TCB10324200 setting property TCP_NO_DELAY (0) 2EE55D8
Jul 12 19:35:56.748: tcp_uniqueport: using ephemeral max 65535
Jul 12 19:35:56.748: TCP: Random local port generated 18087, network 1
Jul 12 19:35:56.748: TCB10324200 bound to 10.20.44.7.18087
Jul 12 19:35:56.748: Reserved port 18087 in Transport Port Agent for TCP IP type 1
Jul 12 19:35:56.748: TCB10324200 getting property TCP_STRICT_ADDR_BIND (19)
Jul 12 19:35:56.748: TCP: sending SYN, seq 1489956361, ack 0
Jul 12 19:35:56.748: TCP0: Connection to 10.25.1.50:1720, advertising MSS 536
Jul 12 19:35:56.748: TCP0: state was CLOSED -> SYNSENT [18087 -> 10.25.1.50(1720)]
Jul 12 19:35:58.748: TCP0: RETRANS timeout timer expired
Jul 12 19:35:58.748: 10.20.44.7:18087 <---> 10.25.1.50:1720 congestion window changes
Jul 12 19:35:58.748: cwnd from 536 to 536, ssthresh from 65535 to 1072
Jul 12 19:35:58.748: TCP0: timeout #1 - timeout is 4000 ms, seq 1489956361
Jul 12 19:35:58.748: TCP: (18087) -> 10.25.1.50(1720)
Jul 12 19:36:02.748: TCP0: RETRANS timeout timer expired
Jul 12 19:36:02.748: TCP0: timeout #2 - timeout is 8000 ms, seq 1489956361
Jul 12 19:36:02.748: TCP: (18087) -> 10.25.1.50(1720)
Jul 12 19:36:10.748: TCP0: RETRANS timeout timer expired
Jul 12 19:36:10.748: TCP0: timeout #3 - timeout is 16000 ms, seq 1489956361
Jul 12 19:36:10.748: TCP: (18087) -> 10.25.1.50(1720)
Jul 12 19:36:11.748: Released port 18087 in Transport Port Agent for TCP IP type 1 delay 240000
Jul 12 19:36:11.748: TCP0: state was SYNSENT -> CLOSED [18087 -> 10.25.1.50(1720)]
Jul 12 19:36:11.748: TCB 0x10324200 destroyed
debug isdn q931
Jul 12 19:37:48.214: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0EA1
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839A
Preferred, Channel 26
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '0723745279'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '0112029999'
Plan:ISDN, Type:Subscriber(local)
Jul 12 19:37:48.214: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8EA1 callID = 0x0053 switch = primary-net5 interface = User
Jul 12 19:37:48.218: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8EA1
Channel ID i = 0xA9839A
Exclusive, Channel 26
Jul 12 19:38:03.218: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8EA1
Cause i = 0x80A6 - Network out of order
Jul 12 19:38:03.378: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0EA1
Jul 12 19:38:03.378: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8EA1
debug voip ccapi inout
Jul 12 19:44:10.279: //-1/4F1E0A638058/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=0723745279
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=0112029999
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Jul 12 19:44:10.279: //-1/4F1E0A638058/CCAPI/cc_api_call_setup_ind_common:
Interface=0x161B8070, Call Info(
Calling Number=0723745279,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=0112029999(TON=Subscriber, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NOT END TO END ISDN(1), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 12 19:44:10.279: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 19:44:10.279: :cc_get_feature_vsa malloc success
Jul 12 19:44:10.279: cc_get_feature_vsa count is 1
Jul 12 19:44:10.279: :FEATURE_VSA attributes are: feature_name:0,feature_time:271239848,feature_id:183
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=0723745279(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=0112029999(TON=Subscriber, NPI=ISDN))
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/cc_process_call_setup_ind:
Event=0x2EB9678
Jul 12 19:44:10.279: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0112029999
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccCallSetContext:
Context=0x31BDCB8
>>>>CCAPI handed cid 183 with tag 0 to app "_ManagedAppProcess_Default"
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=100, Params=0x31C4978, Progress Indication=NOT END TO END ISDN(1)
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccCheckClipClir:
In: Calling Number=0723745279(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Out: Calling Number=0723745279(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Destination Pattern=.T, Called Number=0112029999, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=4F1E0A63-6671-11E7-8058-7426AC319D80, Outgoing Dial-peer=100
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=0112029999
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x272870C, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=0723745279,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=0112029999(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 12 19:44:10.279: cc_get_feature_vsa count is 2
Jul 12 19:44:10.279: :FEATURE_VSA attributes are: feature_name:0,feature_time:271237384,feature_id:184
Jul 12 19:44:10.279: //184/4F1E0A638058/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jul 12 19:44:10.279: //184/4F1E0A638058/CCAPI/ccCallSetContext:
Context=0x31C4928
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccSaveDialpeerTag:
Jul 12 19:44:10.279: //184/4F1E0A638058/CCAPI/ccGetMediaClassTag:
media class tag 0
Jul 12 19:44:10.279: //184/4F1E0A638058/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccGetMediaClassTag:
no peer tag found, use the default media class tag
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccSetMediaclassIp2ipTags:
Jul 12 19:44:10.279: //184/4F1E0A638058/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
Jul 12 19:44:10.279: //183/4F1E0A638058/CCAPI/ccGet_xc_nr_asp_info:
Jul 12 19:44:25.283: //184/4F1E0A638058/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x272870C, Call Id=184
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Jul 12 19:44:25.283: //183/4F1E0A638058/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Jul 12 19:44:25.283: //184/4F1E0A638058/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=184
Jul 12 19:44:25.283: //184/4F1E0A638058/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Jul 12 19:44:25.283: //184/4F1E0A638058/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Jul 12 19:44:25.283: //184/4F1E0A638058/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x272870C, Tag=0x0, Call Id=184,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 12 19:44:25.283: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 19:44:25.283: :cc_free_feature_vsa freeing 102AC100
Jul 12 19:44:25.283: vsacount in free is 1
Jul 12 19:44:25.283: //183/4F1E0A638058/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 12 19:44:25.283: //183/4F1E0A638058/CCAPI/cc_api_get_transfer_info:
Jul 12 19:44:25.439: //183/4F1E0A638058/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x161B8070, Tag=0x0, Call Id=183,
Jul 12 19:44:25.439: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 19:44:25.439: :cc_free_feature_vsa freeing 102ACAA0
Jul 12 19:44:25.439: vsacount in free is 0
07-13-2017 01:59 AM
The called party number being received on the gateway is 0112029999. Couple of things you need to check on the gateway config on CUCM:
>> Do you have the exact '0112029999' DN configured on CUCM ? if yes, then make sure that the 'Significant Digits' setting for inbound calls on gateway page on cucm is set to 'All'. If the called party is configured as a 5 digit extension on cucm then set it to 5, just an example.
>> Check the Calling Search Space setting on the same gateway page for Inbound calls, make sure that this CSS has access to the partition of the called number, 0112029999 in this case. Best way to test is by setting the partition on the called number as None.
>> To rule out any codec mismatch issues , make sure you have the same type of codec specified on dial-peer as well as the the region setting between IP phone and Gateway on cucm, if there is a mismatch then you need to have transcoders in the MRGL of these devices.
Reset the gateway or phone if you make any changes on them and test again.
Manish
- Do rate helpful posts -
07-13-2017 04:39 AM
Hi Manish,
We use 5 digit DN's in our CUCM environment. The Gateway significant digits is set to 5. 29999 is a DN that exists in CUCM.
29999 is in a "none" partition. The gateway is able to reach it.
Our codecs do match and I have Transcoding and MTP dspfarm profiles on the router anyway that are registered and applied to the GW.
07-13-2017 04:43 AM
Well, if the config is all good then probably you can try a restart of the callmanager service and a gateway reset from cucm. If the issue persists you should get the detailed callmanager services traces to see how cucm is handling the call.
Manish
07-13-2017 11:03 AM
Hi Manish,
We have sorted out incomming Voice Calls on the Router.
We are now struggling with the Video portion, to make Video Calls over ISDN. Do you have any idea on how to do this or something similar.
Jul 13 18:01:10.775: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0D1B
Sending Complete Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA18394 Preferred, Channel 20 Progress Ind i = 0x8083 - Origination address is non-ISDN Calling Party Number i = 0x2183, '0112189300' Plan:ISDN, Type:National Called Party Number i = 0xC1, '0112029999' Plan:ISDN, Type:Subscriber(local) Jul 13 18:01:10.775: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8D1B callID = 0x00E9 switch = primary-net5 interface = User ZATJHBCUGPUX003# Jul 13 18:01:10.779: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8D1B Channel ID i = 0xA98394 Exclusive, Channel 20 Jul 13 18:01:10.939: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8D1B ZATJHBCUGPUX003# Jul 13 18:01:20.979: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8D1B Cause i = 0x80AF - Resource unavailable, unspecified Jul 13 18:01:21.147: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0D1B Jul 13 18:01:21.147: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8D1B |
