09-26-2015 12:27 PM - edited 03-18-2019 11:39 AM
Please , I have to implemente BE6000 in a small copany, I want to associate a user to ip phone 7861, I have already created users , and phones bay using BAT.
I am stack in how to attach a phone to each user, and how user can log in the phone ??
Does anyone have an example of an implementation in a samll company.
09-26-2015 02:24 PM
If you're asking about EM, you simple need to create the UDPs for the users, enable EM on the devices, and subscribe the devices to the EM service.
09-26-2015 08:14 PM
Which exact step you are having issues, please elaborate that and we will be glad to help you with
regards
09-27-2015 12:28 AM
1- I powered on the cucm,
2- i iserted ip phones into cucm databse by using BAT.
3- i added users into cucm by using BAT.
4- i want to associate a user to ip phone 7861??
for exemple :
user MAC ADDRESS DESCRIPTION DIRECTORY NUMBER
user 1 381C1ABA5xx Ephone1 1001
5- how user can log in the phone ??
09-27-2015 12:29 AM
FYI, you don't need to associate end user with phone as long as you don't want to use features like EM, Mobility, MVA etc and phone should simply work if DN is assigned to it. Anyway you can go to End User page and you will see the Device Association button, click on that button which will prompt you to assign the Device to respective end user.
09-27-2015 12:55 AM
I need to display the name of each user on his phone,
subsequently Each one will have its own directory.
Thanks.
09-27-2015 03:02 AM
To enable login, you need to create User Device Profile (UDP) for each user and enable Extension Mobility (EM) on all phones. You also need to subscribe all phone to EM service and Associate UDP to users.
You need to export users xls, associate users to UDPs, delete all users, then import you xls
09-27-2015 09:11 PM
Are you using Extension Mobility? As I told you before, if you've assigned static DN to phone under Device page, phone will work normally and user doesn't need to login.
You can configure 'Line Text Label' on DN page to configure whatever you want to display on respective DN/button.
Once you configure end user and assign under group of Standard CCM End Users (on End User page), respective user can login to CCM End User Web Pages and manage own personal directory. Also can login from phone, Directory -> Personal Directory.
Please ensure that under Devices -> Device Settings -> Phone Services, Personal Directory is added and enabled for Enterprise Subscription.
