Asterisk and Cisco call manager Express Integration using SIP
Slim Shady
I'm using cisco router 2901. What is the configuration to be done on the router for the CME and also for the asterisk. I've installed asterisk on linux ubuntu 64-bit on oracle virtualbox.
Please can anybody give me the configurations to be done on both in order to make calls by connecting each other. For the softphones I'm using X-lite and zoiper.
balaji.bandi
High level implementation and it easy to test.
create a SIP Trunk on both the vendors and register each other.
So * will register cisco, Cisco register *, so you have both the SIP communication up
create a dialplan to route the call from cisco to * and vice versa
Many real world example posted, spend 15min you can nail the issue easily.
BB
BB
Can you tell me how to register it * and CME on each other ? If any configuration is available then it would be helpful.
Thank You.
Aeby Vinod
Level 3
Level 3
Yes like Balaji said, shouldn't be complicated, for eg: check this doc out:
https://www.voip-info.org/asterisk-cisco-callmanager-express-integration/
Aeby
Please rate if you find this helpful.
Aeby
In this document I have a confusion. In the asterisk config, do I have to create  separate files for out-ccme, ccme, vm, phones, etc. ?
