ATA 186 replacement
balitewiczp
Explorer
Explorer
Is there an SCCP replacement for the ATA186?  I have seen the 187, but that is SIP only.  thanks
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
8 Replies 8
Rob Huffman
Thank you for the quick response.  I have seen this model before, but have not been able to get it going.  the ATA's were quick, cheap, and dirty.
Rob, undoubtedly you have seen this before.  This is with a VG204
cmapp_sccp_tftp_download_file: Unable to get configuration file size tftp://x.x.x.x/SKIGW1DA2EA6A93.cnf.xml, rc=-2
Is this implying the tftp file is not there?
cheers
Rob Huffman
Hi Pete,
Sadly, I have not seen this before my friend
This does indicate a problem with TFTP though. Here is a sample;
The following is sample output from the debug ccm-manager config-download all command for a
successful SCCP download:
*Jan 9 09:44:45.543: cmapp_sccp_config:
*Jan 9 09:44:45.543: cmapp_sccp_reset_curcfg:
*Jan 9 09:44:45.543: cmapp_sccp_init_curcfg:
*Jan 9 09:44:45.543: cmapp_sccp_download_gw_config_file:
*Jan 9 09:44:45.543: cmapp_sccp_get_gw_name:
*Jan 9 09:44:45.543: cmapp_sccp_get_gw_name: XML file name
generated->SKIGW0C85226910.cnf.xml
*Jan 9 09:44:45.543: cmapp_sccp_get_xml_file_via_tftp:
*Jan 9 09:44:45.543: cmapp_sccp_tftp_download_file:
*Jan 9 09:44:45.543: cmapp_sccp_tftp_get_file_size:
*Jan 9 09:44:45.563: cmapp_sccp_get_buffer:
*Jan 9 09:44:45.575: cmapp_sccp_tftp_download_file: File
(tftp://10.2.6.101/SKIGW0C85226910.cnf.xml) read 8162 bytes
*Jan 9 09:44:45.575: cmapp_sccp_get_xml_file_via_tftp: Read file
tftp://10.2.6.101/SKIGW0C85226910.cnf.xml, len = 8162
*Jan 9 09:44:45.575: cmapp_parse_gw_xml_file:
*Jan 9 09:44:45.579: cmapp_sccp_gw_chardata_handler: ccm found, priority=0
So either the file does not exist or perhaps the TFTP server cannot be reached.
Cheers!
Rob
Yep. saw that output from somewhere, either the doc you forwarded or another.  I'm betting the file is not there, as I can ping the tftp server from the 204.  Time for tAC.   I'll post results
Howdy
Any News on the "cmapp_sccp_tftp_download_file: Unable to get configuration file size " error?
I have the same problem.
cheers
reto
HI.. were you able to resolve this.. Iam getting the same error..
yes, I had to restart my tftp servers
Recognize Your Peers
