07-27-2010 05:28 AM - edited 03-15-2019 11:56 PM
ATA 186 is connected to a CIsco switch & hangs frequently. The distance between ATA & CIsco Switch is more than 70 m.
Is there any specification for supported distance between Cisco switch & ATA 186 ?
Abhas Jain
07-27-2010 07:27 AM
Maximum length for ethernet cable is 100 meters (328 feet). Doesn't sound like you're over the max. Have you tried upgrading the firmware? Using another ATA at the same location?
Brandon
07-27-2010 07:38 AM
I even tried placing IP phone & another ATA 186 at that location but faced same problem. What can be the issue ?
Abhas Jain
07-27-2010 07:41 AM
Have you tested the cable run? Tested/changed patch cables on each end?
Brandon
