02-02-2011 05:23 AM - edited 03-16-2019 03:13 AM
What's the default password/PIN for "Voice Menu" access?
I want to do a factory reset.
thanks
Solved! Go to Solution.
02-06-2011 10:49 PM
Hi, You can try to use CISCO (24726). I hope this helps. Marcos
02-06-2011 10:49 PM
02-07-2011 03:39 AM
CISCO is not the correct password..
tks
02-07-2011 04:05 AM
Strange that CISCO doesn't work.
Could you try 12345, if it still doesn't work try CISCO123.
Pierre.
02-07-2011 04:12 AM
cisco123 and 12345 didnt worked too.
Can i do a factory reset without this password?
02-07-2011 04:37 AM
Is the ATA-187 already registerd with your Callmanager ?
If so, try to change the device "IVR password" to another value.
Pierre.
02-07-2011 04:48 AM
no, unfurtunelly its not registered at cucm.
Thats why i want this password, to access the voice menu to troubleshoot why its no registering at cucm.
02-07-2011 05:03 AM
Did you also try 24727#
Do you know the IP address of the ATA ?
Pierre.
02-07-2011 05:31 AM
24727 didnt worked.
No, i dont know the ip address.
This is one of the reasons i want to access the voice menu, to confirm the IP address.
05-05-2011 04:45 AM
Hello! I have similar troubles too. The Default PIN for new ATA 187 doesn't work. Do you have any ideas?
05-05-2011 06:58 AM
try changing the phone you are using to type the password..
mine was with DTMF problem
07-25-2011 01:36 PM
Hi. Have you resolved this issue?
Do you have a FW between ATA and CallManager? For the ATA you have to open SIP comunication.
When you connect the ATA to a Cisco switch, you can use CDP to verify ATA IP Address. Then use a browser to navigate to the IP Address of the ATA.
Verify with RTMT the TFTP logs of the CallManager, to see if the ATA gets there.
Hope this helps.
Best Regards
