03-25-2011 06:53 AM - edited 03-16-2019 04:09 AM
I've got CUCM 8.5.1.10000-26 and 5 ATA 187
My problem is that sometimes the ATA 187 randomly deregistered and the only solution is power off and power on the ATA.
This happen to all ATA.
I've checked if there is a new ATA firmware but there isn't.
Any idea?
11-07-2018 03:53 AM
Did this firmware worked for you. I couldn't see any post from you after upgrade.
03-25-2015 12:30 AM
Hi Guys
I did following configuration on switchport and it worked for me
speed 100
Duplex Full
Sw mo acc
sw access vlan <voice VLAN>
no sw voice vlan
Regds
04-28-2015 09:46 AM
Good call... I grabbed some SDL traces from CUCM and filtered these traces by mac address of my ATA. I saw that SIP messages where coming from two different IP addresses with that same MAC address. After going through the traces and looking at when the ATA issued the "IP Address Released" status message I was able to find that they were related... After changing the port to be configured for sw access vlan <voice VLAN> and removing the switchport voice vlan command, the customer is no longer complaining about the issue and I am no longer seeing the status messages "IP addr ess released" from the phone gui.
EK
04-23-2018 08:56 PM
