03-25-2011 06:53 AM - edited 03-16-2019 04:09 AM
I've got CUCM 8.5.1.10000-26 and 5 ATA 187
My problem is that sometimes the ATA 187 randomly deregistered and the only solution is power off and power on the ATA.
This happen to all ATA.
I've checked if there is a new ATA firmware but there isn't.
Any idea?
01-16-2013 12:28 AM
Hi again
I've changed the Device Security Profile to UDP only. For me it seems that the ATA 187 boxes are much more stable, and I thought that it solved my deregister problem. But unfortunately I had one box out of 20 that deregistered last week. Not I have added a scheduled job that restarts the boxes every night.
But what a pain that Cisco doesen't have fixed this issue, as such many customers have the problem.
01-16-2013 02:42 AM
Raised a case to Cisco and they have given me a Especial Engineering firmware 9.2(3)ES7 but i didnt resolve the issue.
01-17-2013 01:33 AM
Too bad
It's time for Cisco to inform us about this. I'l ask, is it fair that we have spent alot of cash on a faulty product?
It's so sad
01-17-2013 05:08 AM
Raise a case with Cisco.
01-17-2013 04:02 PM
I tried registering the ATAs to CME but still getting the same issue. It is gotta be a ATA firmware issue.
02-28-2013 04:56 PM
We turned up using Cisco ATA 186. Stable and no issues.
03-01-2013 07:01 AM
Hi rr cuares,
Where did you buy ATA 186? the do not get produced anymore.
Best regards
Kristian
03-04-2013 03:18 PM
We still had ATA 186 but we didn't have power adapters. We bought the adapters off eBay.
04-09-2013 02:09 PM
Try configuring the second port on the ATA 187 to see if this resolves the issue, you don't need to allow it to be able to place a call, We updated the software to ver 187.9-2-3-1 and with the second port configured they seem to have stopped unregistering.
04-10-2013 01:14 AM
Hi John
I'm using both ports on mine 10 ATA 187 boxes. Also running software v. 9.2.3.1. We still have the issue
This is unacceptable. Cisco should exchange them free of charge with ATA 186 or a VG box.
Best regards
Kristian
04-15-2013 06:43 PM
The deregistration issue has been fixed by disabling multicast MoH in both CUCM and VG.
Our anaylsis indicated that ATA187 was receiving high multicast packets (more than 200 pps).
That being said, we havent completely remove all ATA186 in the customer's network as we are still monitoring the ATA187s.
04-16-2013 12:23 AM
Wow that is very interesting news. Do we really have a permanent fix for this issue.
So thats mean that we should try and disable multicast MOH on our CUCM and VG (Voice gateway).
Is there any disadvantages by disabling multicast MOH?
04-16-2013 12:26 AM
SRST MoH wont work. That is the only caveat i know.
04-16-2013 12:59 AM
How do you disable multicast MoH on VG?
04-16-2013 01:16 AM
Hmm I don't think we have multicast MoH enabled on our CUCM and VG :\
Can I get you to say how you disabled multicast MoH on your CUCM and VG?
Thanks in advanced
