AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
291
Highlighted
Participant
ATA-187 does not display SRST reference in browser
I have a ATA-187 running v9.2.1 on a CUCM v7.1.5.
The ATA register correctly in SIP on the CUCM.
For his Device Pool I have configured a SRST reference with the SIP network IP address pointing to the SRST-gwy.
I have applied the config and reset the ATA.
But when I browse to the ATA Network Setup  I do not see the SRST reference on the Call Manager entries (see attached screenshot).
Did I forget something or am I looking at the wrong place?
rgds, Geert.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Enthusiast
Geert,
Do you have both ports configured in the same device pool?  Can you attach the ATA's config file (ATA.cnf.xml)?
Brian
2 REPLIES 2
Enthusiast
Geert,
Brian
Participant
Hello Brian,
After putting the 2nd port in the same device pool the SRST reference correctly appeared on the ATA-187.
Thanks for your great help!
rgds ,Geert.
Content for Community-Ad
August's Community Spotlight Awards
