ATA 187 don´t register in CUCM 8.6
wilsonsant
Level 6
Level 6
Hi Guys,
I am triyng configure one  ATA 187 in CUCM 8.6, but, It don´t register. I verifyed TFTP, DHCP, cable, CUCM, Switch configuration  and didn´t found. Any have idea as solved this problem.
WIlson
20 Replies 20
Hi Chondo,
After to do factory default and reconfigure the ATA 187 worked. Thanks a log
Wilson
Hi Tracy,
This procedure was did, but, didn´t solve the problem. I putted manualy the IP and problem continue.
Thank You,
Wilson
Dang, foiled again! If you run the RTMT do you see that ATA trying to talk to your TFTP server? Double check that you have option 150 configured correctly for your DHCP scope and that you have a helper address, if needed based on your topology, on the correct vlan.
Hi Tracy,
After reset default factory and reconfiguration the ATA 187 It worked. Thanks Lot
Wilson
For me the nor the network settings change to manual and back to DHCP nor ATA from the analog phone made it.
Unlike other devices the ATA 187 did not registered until I had attached a DN to the device on the CUCM. Once I had done than it worked but this is explained nowhere.
ramondelacruz
Add ATA187 device in CUCM. Add DN to Line 1.
Plug ATA187 into configured network data jack or switchport.
Plug an analog phone into Line 1.
Press Setup button on ATA187.
Listen to IVR.
Press 3 to set ATA to DHCP.
ATA187 will then register automatically in CUCM.
