ā03-15-2012 10:57 AM - edited ā03-16-2019 10:09 AM
Hi Guys,
I am triyng configure one ATA 187 in CUCM 8.6, but, It donĀ“t register. I verifyed TFTP, DHCP, cable, CUCM, Switch configuration and didnĀ“t found. Any have idea as solved this problem.
WIlson
Solved! Go to Solution.
ā03-21-2012 07:53 AM
Hi Chondo,
After to do factory default and reconfigure the ATA 187 worked. Thanks a log
Wilson
ā03-21-2012 05:22 AM
Hi Tracy,
This procedure was did, but, didnĀ“t solve the problem. I putted manualy the IP and problem continue.
Thank You,
Wilson
ā03-21-2012 06:19 AM
Dang, foiled again! If you run the RTMT do you see that ATA trying to talk to your TFTP server? Double check that you have option 150 configured correctly for your DHCP scope and that you have a helper address, if needed based on your topology, on the correct vlan.
ā03-21-2012 07:52 AM
Hi Tracy,
After reset default factory and reconfiguration the ATA 187 It worked. Thanks Lot
Wilson
ā09-18-2013 01:41 AM
For me the nor the network settings change to manual and back to DHCP nor ATA from the analog phone made it.
Unlike other devices the ATA 187 did not registered until I had attached a DN to the device on the CUCM. Once I had done than it worked but this is explained nowhere.
ā10-15-2014 01:18 PM
Add ATA187 device in CUCM. Add DN to Line 1.
Plug ATA187 into configured network data jack or switchport.
Plug an analog phone into Line 1.
Press Setup button on ATA187.
Listen to IVR.
Press 3 to set ATA to DHCP.
ATA187 will then register automatically in CUCM.
