946
m.elmaaroufi
Beginner
ATA 187 Fax issue
Hi all,
I'm wondering a strange pb with my ATA 187 registered with cucm 8.0.3, the issue is when i'm sending a fax it will be ok but when i want reveiving one i get the message debug: netwwork out of order via debug isdn q931
my architecture is like:
FAx---->ATA187------->CUCM------------->ALCATEL 4400---------->PSTN--------------------------FAX
my parameters are:
codec g711alaw
modem passthrough nse codec G711alaw
best regards
Med
4 REPLIES 4
priyk
Beginner
Hi ,
From whatever limited information you have provided  :
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Network out of order
The destination is not reachable because of a network                 malfunction. The condition can last for an extended period. An immediate                 attempt to reconnect will probably fail.
If you use a long distance carrier, try to use a Presubscribed                 Inter-exchange Carrier (PIC). For example, you can use a 10-10-xyz carrier. A                 PIC enables you to verify whether the problem lies with the long distance                 carrier.
Thank you for answering, how can i fix it,
best regards
Med
Christopher Graham
A couple of issues with you current config. Do you have a Cisco gateway/CUBE between CUCM and Alcatel?  If not, Alcatel will not support an NSE based switchover as this is Cisco proprietary.  And on that same note, the ATA also does not support modem passthrough.  If Alcatel supports T38, this is your best option.  If not, you will need to set up the ATA as fax passthrough.  Please see the following link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/187/1_0/english/administration/guide/sip/a187_ag7fax.html
I'd like to thank you for your response, i'll test the t38 with Alcatel and waiting what that give, i have configured the ATA in Passthroug before with the parameters mentionned in the documents but without any result, so i'll test T38 and give a feedback about the output, thank you again
Med
Create
Recognize Your Peers
Content for Community-Ad
