03-03-2013 06:38 PM - edited 03-16-2019 04:02 PM
Hi team, I have a CUCME 9.0, I configured an ATA 187 but only the first port works, the second one remains in status registering and does not work.
Thanks for your help
Jose
Solved! Go to Solution.
03-05-2013 03:37 PM
Jose,
Sorry I somehow didnt see your reply before. Can you try the below and let us know how did you go:
no voice register pool 34
voice register pool 33
id mac 04DA.D2BF.27A7
type ATA-187
number 1 dn 33
number 2 dn 34 <<< add this line
dtmf-relay sip-notify
description **ATA-FAX**
codec g711ulaw
Terry
03-03-2013 06:52 PM
Hi Jose,
Can you post the config?
Terry
03-04-2013 05:27 AM
03-05-2013 03:37 PM
Jose,
type ATA-187
number 1 dn 33
codec g711ulaw
Terry
03-05-2013 06:30 PM
Excellent Terry, the two lines are working now.
Thank you very much
03-05-2013 08:21 PM
Not a Problem Jose - Glad that helped!
Terry
