08-22-2011 10:22 AM - edited 03-16-2019 06:36 AM
Is there an MD5 Hash with the 9.2.1 release for the ATA 187? I went to install the software in our development environment and it reminded me to verify the MD5 hash. I went through the release notes and did see any reference to it. I also had this issue with the ATA 187 9.0.3 release, except for this release the MD5 hash value in the documentation did not match the file I downloaded from the Cisco website.
thanks,
Beth
Solved! Go to Solution.
08-22-2011 10:33 AM
Hi Beth,
From the ReadMe that you can only see when you click on "Download now"''
from the Software downloads;
a1:d5:e5:65:4a:19:5d:e8:a8:68:f4:18:8f:be:0b:ef |
http://www.cisco.com/web/software/282074215/51623/cmterm-ata187-9-2-1-0-readme.html
Cheers!
Rob
08-22-2011 10:36 AM
+5 Rob!
Edit: To add to Rob's post, my last post had a different file selected and not the actual firmware file. You can also find the firmware MD5 during the checkout procedure when downloading files from CCO:
Release | 9.2(1) |
Filename | cmterm-ata187.9-2-1-0.cop.sgn |
Release Date | 20/Jun/2011 |
Description | Firmware File for ATA 187 9.2(1) - Compatible CUCM Versions 7.1(5) and higher |
Size | 5348.62890625 KB (5476996 bytes) |
Router Checksum | 0x40cf |
MD5 | a1d5e5654a195de8a868f4188fbe0bef |
HTH,
Chris
08-22-2011 10:33 AM
Hi Beth,
Cheers!
Rob
08-22-2011 10:36 AM
+5 Rob!
Release | 9.2(1) |
HTH,
Chris
08-22-2011 10:47 AM
Hey Chris,
Thanks buddy! Right back at ya
Cheers!
Rob
08-22-2011 01:02 PM
Thanks Rob and Chris for the prompt responses. I really appreciate the information.
Beth
