ATA 187 Release 9.2.1 MD5 Hash?
Beth Verish
Is there an MD5 Hash with the 9.2.1 release for the ATA 187?  I went to install the software in our development environment and it reminded me to verify the MD5 hash.  I went through the release notes and did see any reference to it.  I also had this issue with the ATA 187 9.0.3 release, except for this release the MD5 hash value in the documentation did not match the file I downloaded from the Cisco website.
thanks,
Beth
2 Accepted Solutions
Rob Huffman
Hi Beth,
From the ReadMe that you can only see when you click on "Download now"''
from the Software downloads;
a1:d5:e5:65:4a:19:5d:e8:a8:68:f4:18:8f:be:0b:ef
http://www.cisco.com/web/software/282074215/51623/cmterm-ata187-9-2-1-0-readme.html
Cheers!
Rob
+5 Rob!
Edit:  To add to Rob's post, my last post had a different file selected and not the actual firmware file.  You can also find the firmware MD5 during the checkout procedure when downloading files from CCO:
Release
9.2(1)
Filename
cmterm-ata187.9-2-1-0.cop.sgn
Release Date
20/Jun/2011
Description
Firmware File for ATA 187 9.2(1) - Compatible CUCM Versions 7.1(5) and higher
Size
5348.62890625 KB (5476996 bytes)
Router Checksum
0x40cf
MD5
a1d5e5654a195de8a868f4188fbe0bef
HTH,
Chris
Rob Huffman
Hi Beth,
Cheers!
Rob
+5 Rob!
Release
9.2(1)
Filename
Release Date
20/Jun/2011
Description
Size
Router Checksum
0x40cf
MD5
HTH,
Chris
Rob Huffman
Hey Chris,
Thanks buddy! Right back at ya
Cheers!
Rob
Thanks Rob and Chris for the prompt responses.  I really appreciate the information.
Beth
