164
Beginner
ATA-187's in my System
I have about ten ATA-187's currently deployed around my organization, and a small pile of them on the shelf left by my predecessor. I'm going to need another ATA deployed soon, but with the 187 EOL for a long time I'm looking for a suggestion on its replacement.
More to the point, is there a reason I should upgrade the deployed 187's that are generally working fine?
Thanks!
-John
4 REPLIES 4
Frequent Contributor
Re: ATA-187's in my System
What system?
CME? CUCM?
Beginner
Haha, whoops. CUCM 11.5
Highlighted
The ATA191 is now the current ATA
But if you can find ATA187, they also work
Beginner
Thanks.
Are there any security implications in using a device that won't see any firmware updates? Same question also applies to our older phones, such as 6945 and 8961.
My IT management is big on security, I have good budgets, and they generally don't care for devices that are EOL. The 187's work just fine otherwise.
Content for Community-Ad
August's Community Spotlight Awards
