05-19-2013 11:01 AM - edited 03-16-2019 05:24 PM
I'm trying to test an ATA-187 on our CUCM with a fax and when it answers on the first call it drops the call. When the sending machine redials the ATA will answer and receive the fax. I dropped the max baud rate on the ATA down to 2400 and it works every time. Any suggestions???
Solved! Go to Solution.
05-19-2013 03:35 PM
Hi Jamize,
Have you try with another fax machine? Maybe the fax machine has a 2400 baud limitation.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
05-19-2013 03:35 PM
Hi Jamize,
