ATA 187
unitedriders
Beginner
Beginner
Can I use the ATA 187 as standalone SIP device in my network? I do not have a CUCM, I am connecting to an asterix or similar gateway.
Thanks!
1 REPLY 1
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Technically sure, with SIP load you should be able to register it to any SIP Proxy, Server, etc. Whether it will work reliably is a different story and it depends on Astreix's SIP compatibility.
HTH,
Chris
