ATA-190 drops registration
Evgeny Andreev
Beginner
Beginner
hello
cucm 8.6.2
have got  5 ata-190, and all of them have one problem - it drops registration and became unregistered after some period of time. after reboot it works fine several days and then drops it again.
tried different firmware (now it is  ATA190.1-1-2-005), but it doesn't help
ATA-187 works fine.
18 Replies 18
Gordon Ross
Engager
Engager
The current, latest, public ATA 190 firmware is 1.2(1)4.
Try that first.
GTG
Please rate all helpful posts.
Couldn't upload this firmware, cause recieve
'Error encountered: The selected file is not valid'
Did you find any solution? we are facing the same issue.
We have the same problem with both ATA 190 and the newer ATA 191 also. Hope somebody has found a solution or Cisco fixes it.
We have the same problem with our two ATA191's. We go about 1 month and then the ATA stops working.  The connection to the switch remains active, but the registration drops, we can't ping them, and no IPv4 Address is listed in CM.  They have to be power cycled in order for them to work again. Using Call Manager 12.0.1.22900-11
Our older 187 ATA's never had this problem.
I have same problem anyone get resolve from cisco?
robertwells1
Beginner
Beginner
We ordered 13 ATA 191's and are having this issue. They stay registered for 20 minutes or so, then drop registration. The IP, and Registration status dont appear in cucm (ver.11.5 SU4).
Tried to upload latest firmware, still no luck. Anybody with a fix?
No fix yet.  I've tried factory resetting and setting them up statically multiple times and the ATA's will still drop registration anywhere from 2 days to 2 weeks later.
Did you still test the last Firmware 1.2.2 SR1
In the Release Notes  there is no mention about this issue.
We have some problems too, we will probably search an alternative to these devices.
Mirko
Same issues here with CUCM 11.5.1
TAC does not find solution till months!
I think we finally found a fix! We have been stable now for over a month.
We were given the following action plan from TAC:
Action Plan
Please go to phone >> device >> ata devicw >> search for this parameter and disable line 2 ; click on save and then apply config
Try that out and see if it works for you.
Thanks for your answer, we tried this already but this doesn't fix the problem for us.
Best regards
Werner
Did this TAC recommendation work for you ?
search for which parameter ?
Recognize Your Peers
