ATA 190 - Not able to save a static IP
Good morning,
we are trying to configure an ATA190 with static IP. However is driving me crazy... it is impossible for me.
I am able to change the mode from DHCP to Static.
I enter ****
then 101 - 1
At this poing everything look good, however I am not able to do the next steps.
I enter 111
and them the IP, I have tried with all number and with dots
192.168.109.2   /192168109002
However when I enter the show ip address ivr code: 110
The IP is not there.
This is the same for the mask and the gateway.
Is there something I am missing?
Anyone have it in static mode.
Thanks in advance.
PD: The codes I use are here.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_agBcd.html
Marcelo Morais
VIP Advisor VIP Advisor
VIP Advisor
please, try to Factory Reset the ATA 190 (code 73738) and try again.
Best regards,
Marcelo Morais
Hi Marcelo.
I will try it today. I will let you know if are lucky.
Thanks.
Roberto.
No luck, same resullt.
Recognize Your Peers
