ATA-191 Resetting on apply config can it be turned off
khenning
Beginner
Beginner
Good Day,
We are a school district using multiple ATA-191's  These ATA's are being used as a second monitoring line for our Fire Alarm panels.  What is happening is that when I do a config change on a ata and hit apply config the ATA reboots and so this causes the line to drop and then the monitoring company calls us as they get a line fault on their end.  Would there be a way around this so the ATA does not reboot?  The old ata-186's would still putt out battery voltage on reset so we did not have issues then but since the 186's are going away we put in the 191's
Kevin
0 Replies 0
