01-08-2019 05:31 PM - edited 03-18-2019 12:35 PM
Hi Experts,
I have ATA 191 and is registered in Call Manager 11.5 SU4. However, when trying to access via Web, page does not load.
Web access is enabled in phone configuration. ATA is on the same subnet as the phones and I can access the other phones Web GUI, just except for ATA 191. Am I missing something? Thank you.
Flo
01-08-2019 08:27 PM
01-08-2019 09:46 PM
01-08-2019 10:29 PM
01-08-2019 10:33 PM
01-09-2019 01:08 AM
01-09-2019 07:14 AM
I had a similar issue using an ATA-191 connected to Call Manager Express, and in order to get the webGUI working I added an admin password to the telephony-services configuration.
service phone webAccess 1
service phone adminPassword 1234
However the web page only allows me to view stats and not modifying any config....and I don't know if there is a way to allow config changes through the webGUI
05-13-2019 10:36 AM
Setting an Admin Password on the CUCM Device Config page worked for me.
Admin Password* | Set the password to access the Web Administrator interface. |
Would be nice if they made it a little more clear that this is now REQUIRED in order to access the Web Admin interface.
Thanks for the tip!!
05-13-2019 12:11 PM
06-30-2019 11:11 AM - edited 06-30-2019 11:13 AM
THANK YOU!!!
WTF, I was seriously confused until I came across this post (more used to ATA 190s). So now I can get to the webpage, but still can't log in. I've tried username: admin and username: cisco coupled with the Admin Password I set, but login fails. Also tried cisco/cisco and admin/admin. Any idea what the username is supposed to be?
06-30-2019 06:43 PM
Username should be: admin
Password should be whatever you set on the CUCM device config page for "Admin Password".
Also, make sure you have "Web Access" set to: Enabled.
07-01-2019 06:32 AM
I swear I tried that yesterday and it didn't work. Sure enough, just tried it this morning and got right in. Thanks!
06-30-2019 11:12 AM
THANK YOU!!!
11-05-2021 12:19 PM
Jeremy,
I can get to my web page and have set a password in cucm. I am unable to log into my web interface Is there a default usename? I have tried admin and cisco.
11-08-2021 07:04 AM
The default username should me: admin
