AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
273
Highlighted
Beginner
ATA and faxes issue
I configured an ATA. Its a CME based system. CME version 8.6
I tested inbound and outbound faxes and it did work. But customer complained that some of their suppliers are having issues sending faxes to them.
I tested once the fax went through and another time it failed. It seems quite intermittent.
Any suggestion would be appreciated. Please find the config below
ephone 45
device-security-mode none
mac-address 000C.3052.8E3B
ephone-template 1
max-calls-per-button 2
type ata
button 1:55
ephone-dn 55 dual-line
number 8099
dial-peer voice 50 voip
destination-pattern 8099
modem passthrough nse codec g711ulaw
session target ipv4:192.168.150.58
codec g711ulaw
fax rate disable
no vad
voice service pots
fax rate disable
voice service voip
Please rate the post Shibly Ibrahim
Everyone's tags (3)
4 REPLIES 4
Contributor
ATA and faxes issue
Pls Try the below and return back wiith a feedback
voice service voip
fax protocol pass-through g711alaw or ulaw
modem passthrough nse codec g711alaw ------->or ulaw
codec g711alaw   ------------->or ulaw
fax-relay ecm disable
no fax-relay sg3-to-g3
dtmf-relay h245-alphanumeric
fax rate 9600
fax protocol pass-through g711alaw -------->or ulaw
no vad
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Beginner
ATA and faxes issue
Hey Chrys,
Thanks. I was making the changes and in the meantime I had a tac case logged with cisco. She said I wouldnt need the dial-peer at all since the analog device would be a device part of the system and therefore the dial-peer is not necessary.
I have removed it and tested twice waiting for customer to get back to me on this.
Beginner
ATA and faxes issue
Chris by the way thanks for the help. If this doesnt work I am going to use your solution and see.
Contributor
ATA and faxes issue
You are very welcome
Pls return back when the problem solved to update the case
Will help  other people with the same issue
Content for Community-Ad
August's Community Spotlight Awards
