05-25-2011 10:01 PM - edited 03-16-2019 05:09 AM
Hi Experts,
We have some issues with our ATAs since we migrated our GWs from MGCP to H323.
-Line 2 on ATA has issues both inbound and outbound
-Instance of not getting dial tone on one or both ports
Here're some of the settings:
LBR Codec 3
AudioMode 0x00350035
ConnectMode 0x90000400
MK
05-26-2011 06:36 PM
Anybody with any ideas?
05-29-2011 09:34 AM
Still looking for some help.
05-29-2011 02:49 PM
Have you tried skinny? It may make things easier then mgcp or h.323 .
In any case, no dial tone has nothing to do with codec since the dial tone is generated locally by the ATA.
If the problem happens after dialing, then I would look at the call termination point (pstn gateway perhaps) and try to find out what is going on.
Kind of hard to be specific without more details here, hope that helps.
05-29-2011 08:16 PM
Thanks for the reply. As I mentioned the ATA is skinny (SCCP) and the PSTN GW is H323. Please let me know if you need more details.
05-29-2011 08:54 PM
ok, in that case what directory number is assigned to one of the ATA that has issues?
also, please post the output of 'show dial-peer voice summary' from the H.323 gateway.
thx, Avner
05-29-2011 09:04 PM
Here's the dial peer configuration
dial-peer voice 1 voip
destination-pattern 234567....
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
voice-class h323 1
session target ipv4:X.X.X.X
dtmf-relay h245-signal h245-alphanumeric
fax-relay ecm disable
fax rate 14400
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
ip qos dscp cs3 signaling
no vad
dial-peer voice 2 voip
preference 1
voice-class h323 1
fax rate 14400
no vad
dial-peer voice 130 voip
voice-class h323 1
incoming called-number .
fax rate 14400
no vad
dial-peer voice 110 voip
voice-class h323 1
fax rate 14400
no vad
05-29-2011 11:55 PM
Ok thx, looks like u are using the default codec (g.729) under the dial peers. The ATA can only support 729 on port 1, if it's not a problem u should add a 'voice class codec' config, enable 711 and 729 in it and assign it to the dial peers.
This should help, if not send the output of 'debug VoIP dialpeer' for a failed call .
05-30-2011 09:12 PM
Thanks Avner,
I will apply the config and let you know.
MK
