ATA186 (SCCP) problem dialing "*"
Velimir Filipov
Level 2
Level 2
Hello fellows,
I have a problem with ATA186 with SCCP registered to CME on 2811 voice router.
Whenever you dial asterisk "*" as the first symbol in the dial string, its just not seen by the CallManager
So if i dial *3, on the callmanager i see just 3.
But if put the asterisk on any other position, it shows up..
Has anyone encountered such issue ?
Thanks in advance.
The * is per default used by the ATA186 as a trigger for pre or mid call features.
See more at this URL, http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/3_0/english/administration/guide/sccp/user.html
Please remember to rate all useful posts.
Response Signature
Velimir Filipov
Level 2
Level 2
Ok, i guess i didnt provide enough info.
ATA186 (SCCP)
S/W Version     3.02.04(090202A)
H/W Version     0x0014 0x0000
Product ID     ATA186I2-A
Router is Cisco 2811
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
CONFIG (Version=8.1)
Version 8.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Response Signature
Thank you very much!
Is there any way to disable Pre-Call services, not only change the prefix for it ?
Best regards.
Have you looked at this, https://supportforums.cisco.com/thread/283564
Response Signature
