ATA187 how to configure
CARLO CALABRESE
I just got the ATA187 and have them working. I need to know if there is a way to change settings via a web page? Can't find anything in the online manuals. The part I need to change is turning off the second port. A lot of times we put them next to a fax machine and don't need the second port. I don't want to waste my DLUs.
Any help?
9 Replies 9
dksingh
I don't have access to an ATA 187 presently but can u go to
your CCM ATA page and click on its IP and provide a screen
shot of the ATA's web/gui ?
Felipe Garrido
Unlike the ATA 186/188, the 187 can only be configured via CUCM.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps514/ps11026/data_sheet_c78-608596.html
Under, Cisco ATA SIP services
• Cisco ATA configuration through Cisco UCM configuration interface
The ATA configuration has been simplified and streamlined to mimick that of an IP phone. All available options are now on the CUCM page for the ATA.
-Felipe
My question is, How do I turn off the second port. Like the 186, it has a second mac address and that burns up my DLUs.
Workaround.
Turn off autoregistration and add devices manually.
cheers,
i
wildflower1977
I have the exact opposite problem, I have manually configured two fax machines on the ATA187 and the 2nd line doesnt work at all.  Where in the settings do you configure this?
In CUCM, you need to add an ATA18[67] device for each FXS port. Second ATA18[67] device has "shifted" MAC address.
"The first device used the MAC address and the second device uses the shifted MAC address (example, AABBCCDDEEFF to BBCCDDEEFF01). You can add two devices from the Unified CM administration page."
More details in admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/187/1_0/english/administration/guide/sip/a187_ag2str.html#wp1102295
Hope this helps,
cheers,
i
so just to clarify, I need to remove the first 2 digits and add 01 on the end? or is it the next pair in the sequence?
the MAC address is 2D:BB:09:E3:FA:9D, so change it to BB:09:E3:FA:9D:01 or BB:09:E3:FA:9D:9E?
Drop the leading digits, and add 01. So your first example is correct.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
CARLO CALABRESE
There is no way to shut off the second port in a large system.
