| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getIpBySrvHost2(83) line(0) Resolving(proxy.sip.sapo.pt) port(5070), rc=4 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getIpBySrvHost2(122) line(0), type=2 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getIpBySrvHost2(137) *ipv4=0xf10241c2, ipv6=, rc=0 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getNextHopTransportPar2(486) rc=4 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getNextHopTransportPar2(532) line(0) type=0 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_getNextHopTransportPar2(554) tp->uiIp=0xf10241c2, strIpv6=, rc=0 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: [0]->194.65.2.241:5070(633) |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: REGISTER sip:proxy.sip.sapo.pt:5070 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.81:5060;branch=z9hG4bK-57a5b643 From: \"+351302004171\" <sip:+351302004171@proxy.sip.sapo.pt>;tag=b7e3889f754ab327o0 To: \"+351302004171\" <sip:+351302004171@proxy.sip.sapo.pt>Call-ID: e2469ba3-e1391b7a@192.168.1.81 CSeq: 17814 REGISTER Max-Forwards: 70 Contact: \"+351302004171\" <sip:+351302004171@192.168.1.81:5060>;expires=3600 User-Agent: Cisco-ATA192-MPP/11-2-1MPP0001-006 P-Station-Name: ;mac=b0c53cd802de; display=\"\"; sn=FCH24503TXV Content-Length: 0 Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER Supported: replaces, sdp-anat</sip:+351302004171@192.168.1.81:5060></sip:+351302004171@proxy.sip.sapo.pt></sip:+351302004171@proxy.sip.sapo.pt> |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_logRxMsg(844) lid[0]<<194.65.2.241:5070(523) |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP/2.0 403 Forbidden 110200201005001 Via: SIP/2.0/UDP 192.168.1.81:5060;received=85.244.166.135;branch=z9hG4bK-57a5b643;rport=5060 From: \"+351302004171\" <sip:+351302004171@proxy.sip.sapo.pt>;tag=b7e3889f754ab327o0 To: \"+351302004171\" <sip:+351302004171@proxy.sip.sapo.pt>;tag=0f9130cc01a84905c91e7ecc12d3 Call-ID: e2469ba3-e1391b7a@192.168.1.81 CSeq: 17814 REGISTER Content-Length: 0 P-Charging-Vector: icid-value=n2m09046p1ds2rk6ehcs2pg6hhoamfde9rpulo462j3pi1vg;icid-generated-at=194.65.2.241;orig-ioi=internet</sip:+351302004171@proxy.sip.sapo.pt></sip:+351302004171@proxy.sip.sapo.pt> |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_regTsEventProc(event: 28) |
| Aug 9 12:14:56 ATA192-MPP local1.warning vsock: MONITOR STOP Error [Not Found] [REG Check, 0] |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: regCleanPendingTs(), enter into regCleanPendingTs |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: [0]RegFail. Retry in 1200 |
| Aug 9 12:14:56 ATA192-MPP local1.debug vsock: SIP_regTsEventProc(event: 32) |
| Aug 9 12:14:59 ATA192-MPP local1.debug vsock: SAFE_MON_main() ccTick:64->164, ccCnt=0->59, monNum=0 |
