08-19-2016 12:50 AM - edited 03-17-2019 07:52 AM
For the Cisco Attendant console I would want callers to hear a initial greeting such as "welcome to XXXX your call will be answered shortly"
would that need to be done via Unity connection call handler?
Also if they are held in a queue, what is the best way to input a customised anouncement?
08-19-2016 03:25 AM
yes , this can be achieved by Unity connection. You have to forward the calls for your main line to call handler configured on CUC.
08-22-2016 01:16 AM
Thanks everyone for your input. I thought it was the case.
08-19-2016 03:28 AM
you can also record prompt using cuc but u will need java for this.
08-19-2016 03:33 AM
We also offer Attendant Console along with QueueManager solution, where the greeting is built in and you can modify as per your needs as well.
You can check for the solution here: http://www.commsouth.com/UCC-Applications.php
Prasana Kumar
(prasana@commsouth.com)
08-19-2016 07:38 AM
You can accomplish everything in CUCM if you are using the hunt group with native call queuing to support the attendant console.
Here's an excerpt from the feature guide linked below:
The Call Queuing feature provides an enhanced capability to handle incoming calls to a hunt pilot number. When an incoming call reaches the hunt pilot, the following capabilities are provided:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_0_1/ccmfeat/CUCM_BK_CEF0C471_00_cucm-features-services-guide-90/CUCM_BK_CEF0C471_00_cucm-features-and-services-guide_chapter_0111.html
