running CM 8.6(2) and with Attendant Console 8.6(2). This version of AC is only supported on Server 2003 and Server 2008 R1. There is a need to upgrade but I am having trouble determining if we can run a version of AC on Server 2012 R2 that is compatible with Cm 8.6(2). CM will be upgraded soon but for internal reasons the server that AC is on needs to be upgraded first. if at all possible. No UCS servers available either. Only ESXi5
The install/configuration guides for the ACs have all requirements, including supported OSs and CUCM compatibility, have you reviewed the one from the version you want to upgrade??
java
if this helps, please rate
Learn, share, save
