Audio Alarm in IP Phone (CCM 7, IP Phones, 7960/7970/7975)
ifthi.cisco
Dear All,
Can we play "Alarm" or some "Audio" at a particular given time in IP Phones?
Or some logic which can help with the above task??
Like about creating Custom Ringtone and playing that audio/tone automatically at a specified interval of times without any intervention?
Any ideas/suggestions will be highly appreciated.
Thanks in advance!
Ifthiquar
Marcel Ammann
Level 3
Level 3
I think it Is possible with UCCX or CUE, but you Must create a script.
Kind regards,
Marcel Ammann
P.S.: Rate helpful posts
Marcel Ammann
Level 3
Level 3
Kind regards,
Marcel Ammann
i have new information's for the above post:
Alarm Service
An alarm service is used to be informed on the IP phone at a specific time. Alarm can be easily created on the phone and at the alarm time an acoustical and optical signal is generated.
The alarm service includes a web interface to manage all alarms in the environment which is especially useful for receptionists.
http://www.andtek.de/en/communications-products-andapps.html
You need one server licence + the "apps" - licence. The APAS Server runs also in VMWare ESX(i).
Also you can become a trial and try the andtek product-(suite).
Kind regards,
Marcel Ammann
Pranjol Saikia
Level 4
Level 4
It can be done using a 3rd party application.Pls check out http://www.parsec-tech.com/index.html for Cisco IPT Applications.
