11-01-2013 09:30 AM - edited 03-16-2019 08:11 PM
Hello
I am getting reports of a number of dropped calls and spotty audio quality from my users in a location where we recently upgraded the office to VOIP. Initially, I was on the phone to the carrier but they said there was no issue. Now I am thinking it may be related to the clocking of the PRI lines
I need some guidance on the best way to ensure the clocking is correctly sync'ed up so that there is no PVDM issues which may be resulting in choppy audio and/or dropped calls.
The inventory is a 3945e with an NM-HDV2-2T1/E1installed on slot 1 with pvdm2x64 on this.
On port 1/0 is a TDM e1 trunk with clocking set from 'line'
On port 1/1 is a TDM e1 trunk with clocking set from 'line'
On port 2/0 is a digital PRI line. This did not support clocking from the line so initially I was getting slips and errors. So I set the command 'clock source internal' and this got rid of the slips and errors.
The other commands I have are:
network-clock-participate slot 1
no network-clock-participate slot 2
network-clock-select 1 E1 1/0
network-clock-select 2 E1 1/1
So - could anyone please help and advise if one, It is possible for the audio issues to be a result of clocking incorrectly and two if there is a way to verify if something is wrong.
Show network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
1 E1 1/0 GOOD E1
2 E1 1/1 GOOD E1
10 Backplane GOOD PLL
Current Primary Clock Source
1 E1 1/0 GOOD E1
11-01-2013 12:52 PM
Why are you so sure is related with the PRI clocking? If you migrade recently to VOIP it could be a QoS issue.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
11-03-2013 05:50 AM
nope I'm certain it ain't qos
is there any guide available regarding clocking of pri lines etc
11-03-2013 08:55 AM
E1 PRI from telco, should have clock from line, and highest network-clock priority.
Then you would have to check again on "show controllers e1" and drop cause.
11-03-2013 08:00 PM
the relevane part is " to ensure a synchronised system, you must configure a master clock within the network , and distribute and recover the clock throughout the network.
If you cannot configure a synchronised system, then you can configure multiple clock sources on your network as long as they are accurate enough that the clocking on both clocks sources will match.
